Originally Posted by aschrager
I checked the owner's manual and you are correct there is a procedure to adjust the aiming (pg 44) Could you all look at it and see if you can find the level they talk about. I don't see it.
Picking up on an old thread, I replaced both my low beams in a span of a week. but they are not aimed correctly at all.
First, i can see to find the proper seating for these bulbs. I see there is a short tab at the bottom of the ring on the bulb and that slots into a slot in the head lamp fixture. However, its not what you would call "precision" it can vary up and down. If i'm going about this wrong can someone advise?
