Old May 31, 2007 | 04:15 AM
simon-srt6's Avatar
simon-srt6
Default Re: Whine/drone at tick over
Originally Posted by HDDP
There shouldn't be any air in the system... They should have bled the system after the repair... Open the top of the fluid reservoir (fill if necessary) start the car, have a helper turn the steering wheel back and forth from lock to lock a few times while you look into the reservoir. If the fluid becomes slightly foamy on the top, you have air in the system...
https://www.crossfireforum.org/forum...1&d=1180542694
Thank you for the information, I will look at it tonight. The dealer said air in the system was normal after this sort of job and it would clear itself over a few days. Just can't trust what a dealer says, can you ? At least the steering operates normally now, when I first collected it felt lumpy and juddered a bit.
I am back to the dealer on Saturday to get my Exhaust re aligned as they fitted it wonky. I will show this information to them then too.
