Originally Posted by Bostonsrt6
Ok cool did you cut all the bolts on all four wheels? I am assuming 1/4 inch correct? Also the bolts I would be cutting down are not the stock ones...they are ones the wheel company sent me and are already shorter. Did you cut the stock ones or aftermarket ones?
Thanks.
i only needed to shorten the rear bolts, i'm using the H&R 25 mm spacer and aftermarket bolts.
