Old Apr 20, 2004 | 10:00 AM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: Missing Front Bumper Clip?
Originally Posted by C_Plunkett
While looking around under the front of my car, I noticed that there appears to be a clip (or screw) missing where the front bumper should attach to the black plastic belly pan under the engine. At the bottom, center of the bumper, there is a tab sticking back with a hole in it, and there is a matching hole in the belly pan. I assume there is supposed to be a clip there, but I looked at three other Crossfires on the dealer lot this morning and none of them had anything in the hole.
I will call the dealer later today, but was just wondering if anyone else had noticed this, or could confirm that there is supposed to be a clip there.
Thanks,
Craig
none of the crossfire's come with the center clip/pin for the lower front bumper (underneath-center)...i added one to mine.
here you go. the clip is similiar to the clips used in the crossfire's rear cargo area to hold the side trim panels in place.
