Originally Posted by andrew
i did attempt to have an alignment completed but...
it was still in aligned once lowered... no adjustments could be made via the alignment company when i took it in. they only charged me to check it (tracks perfect with no wear front or rear).
and you are correct negative camber indeed in the rear... but no inner wear of the tires.
hope this helps.
Thanks for going to the trouble with the pictures Andrew, does the drivers side lean in more than the passengers side does or is it just the angle of the camera? That's weird about the front, if it had negative camber I would have thought an alignment shop would have adjusted it or did the front not have negative camber? The front does look straight up & down in the pictures. Oh and I think I see a speck on the left side of your rear bumper.
