Old Jun 16, 2007 | 10:25 PM
alfdoc's Avatar
alfdoc
Default Re: Rear axle differential - Seal
The friction gauge [or better known here in the U.S. as a torque wrench] is for setting the pinion bearings preload, if this is not set at the correct friction [or drag] you could damage your pinion bearings and possibly your pinion and ring gear, that is in the rear differential . Save your self a lot of time and possibly money and leave it to the professional.
