Old Jun 16, 2007 | 10:55 PM
blacklimitedcoupe's Avatar
blacklimitedcoupe
Default Re: CUSTOM Door lock pins and RADIO *****
Originally Posted by maxxm
How easy is it to remove and replace the OEM parts (door pins and radio *****)? Thanks.
Very easy...the door lock pins just unscrew and the new ones screw on...you can just use your hand to unscrew them because they shouldn't be too tight...the radio ***** just pull off...I used a credit card to slip under the radio ***** and pop them off...the new radio ***** have a rubber cap that goes onto the radio shaft and then the new **** just pushes on...very easy to do...
