Originally Posted by andrew
i believe it is held in by press clips... i would use a drivers license or credit card and attempt to slide it under an edge and pry gentle... it should begin to release.
If you remove the radio, you will notice 2 small phillips head screws (one on each side) above the radio opening. You must remove these before trying to remove the silver trim...
