Old Jun 26, 2007 | 11:50 AM
Shade's Avatar
Shade
Default Re: Eibach Tech Support
Steve, did you double-triple check to make sure that the bottom end piece of the Eibach spring fit perfectly into the car's bottom spring mount groove slot?
I did not remove the rear shock so maybe the bump stop is at the top of the shock mount location inside the trunk.
I noticed that my rear top spring pad was #3. But my rear drop was nearly equal to the front because I have about 60 pounds of stereo equipment in the trunk and the max drop happened right away.
Rear
A 210 325 01 84 (5mm)
A 210 325 02 84 (9mm)
A 210 325 03 84 (13mm)
A 210 325 04 84 (17mm)
Shade
