Old Jun 26, 2007 | 04:59 PM
Steve Hellums's Avatar
Steve Hellums
Default Re: Eibach Tech Support
Originally Posted by AMGLover
Number 6 in drawing is the spring isolator...not a bump stop on shock that would kill the shock body. Did you try unhooking the sway bar?
Not yet, but I think I'm going to jack the car up and set the rear tire's back down on a couple concrete blocks. Then get under the car and loosen up the sway bar and all the bolts on the lower control arms with the weight of the car on them tonight when I get home from work.
