Here is the enclosure installed. It arrived today so I threw it in right quick. The build is quite nice, and this is a good value. I replaced the grey "trunk liner" carpet that came on it with a black fabric that is the perfect match to the seats in a base coupe. The only thing to be aware of it I had to make the speaker hole larger. If you are running anything other than JL Audio, you may have to do this. I test fit both the RE AUDIO that is shown and a Diamond Audio and the hole need to be enlarged for either sub. No big deal, just pull out the trusty jig saw and get to cutting!
A great fit in the car, and I will demo it later tonight. The weather is BAD here in Dallas and I will get out on the road after the storm passes!
Overall a great buy if you want a clean set up for your Crossfire! Thanks NAZAR!!!
