Thread: Zaino
Old Jun 29, 2007 | 08:50 PM
XFireHammer's Avatar
XFireHammer
Default Re: Zaino
Zaino is what I use as well... Z2 or Z5 with ZFX provides a Long Lasting Shine!
However I've had a problem using their Grand Finale Spray Seal. It could be my application of the product but I've tried several methods and usually get a haze that must be removed with the Gloss Enhancer, so I've steered away from it.
I use AutoGlym to clean the Engine compartment, and the Sonus "Trim and Motor" Kote to enhance the rubber, (not plastic) which gives a new car waxy look in the engine area.
To enhance the trim and rubber I use first use Mequiars Exterior Trim Detailer Spray to clean the surface then I use Sonus "Total Eclipse" to give a nice beautiful shine.
For my tires I use Mequiars High Gloss Gel, which really gives a long lasting moderate shine (and smells like grapes).
As you can see, I've collected a few different products that I like from different vendors; as I'm sure you will too! The trick is to find the right combination that you feel comfortable with, and go with it.
Just my 2 Cents worth!
Good Luck,
XFH
