Originally Posted by BLACKSRT-6
Solo II Racer, can you post some photos of your exhaust and trailer hitch set up? I have been wondering how I was going to be able to carry another set of wheels. Also, what are you running for alignment settings? Thanks.
I had already posted a picture of it but here it is again.
The hitch is custom and consists of the receiver tube and two 24 inch long pieces of steel strapping. The strapping is bolted to the trunk floor and reinforced. It is good to pull a tire trailer but I wouldn't recommend putting anything with more than a 200 lb tongue weight on it.
My alignment settings are -1.5 degrees camber in front with 1/8 degree toe out and -1.2 degrees camber in the rear and 0 toe.
