Old Jul 5, 2007 | 03:08 PM
HDDP's Avatar
HDDP
Default Crossfire Tuner Forum
Just wanted to let you all know that the guys over at http://www.tunertools.com just set-up a new forum for us Crossfire / SLK320 / SLK32 owners... This site will give you access to some specialists in data logging, piggyback systems, wideband 02 sensors, ETC...
Hi Derek,
I just set up a new forum space specifically devoted to the Crossfire / SLK320 / SLK32
http://tunertools.com/forums/forumdisplay.php?f=25
Enjoy. :-)
Brian Palmer already has PCMSCAN set up to accept an additional analog signal from the AEM 30-4100 and the Innovate Motorsports LC-1 set up. In addition, I have a new AFR meter that includes live engine RPM (not through the OBD port) so RPMs don't have that lag that the OBD information does. See this link: http://tunertools.com/proddetail.asp?prod=SP-AF-5000
I believe Brian Palmer could easily incorporate this Sniper AFR meter into PCMSCAN although I'm not so certain about getting BOTH the afr and rpms coming in... since PCMSCAN is set up to get rpms from the OBD port, it might be tricky to place that switch in there for an alternative source of RPM data.
Cheers,
Lloyd
