Old Jul 5, 2007 | 05:35 PM
woody's Avatar
woody
Default Re: ECU DATA Acquisition System
Originally Posted by HDDP
I am also awaiting delivery of the CARSOFT maintenance software which will interface with the ELMSCAN5... But, I am not yet sure that the Mercedes SLK320 software will be the same as the Crossfire... You can find the info for yourself here http://www.carsoftsales.com/mb/index.htm
Enjoy the info... When I have more on the tuning software I will share it with the forum.
Good to hear you got your OBD setup running Derek. The Carsoft software runs fine on the Crossfire but not sure it runs with the ELMSCAN though? I am running version 7 with a third party interface box. You can get access to most of the car's modules that sit on the CAN bus, it even picked up some codes in the ABS module which I had not been able to access before. You can also use it to reset the adaptation codes in the ECU. I used it after replacing the MAF as it ran like a dog having adapted to the original one. It will also recode the ECU to a specific car if you are swapping them out.There are some modules it won't talk to though and mine insists that I have a problem with the hydraulic roof when a run the full diagnostic report! I'll try and post up some pics when I get chance.
