Originally Posted by woody
Good to hear you got your OBD setup running Derek. The Carsoft software runs fine on the Crossfire but not sure it runs with the ELMSCAN though? I am running version 7 with a third party interface box. You can get access to most of the car's modules that sit on the CAN bus, it even picked up some codes in the ABS module which I had not been able to access before. You can also use it to reset the adaptation codes in the ECU. I used it after replacing the MAF as it ran like a dog having adapted to the original one. It will also recode the ECU to a specific car if you are swapping them out.There are some modules it won't talk to though and mine insists that I have a problem with the hydraulic roof when a run the full diagnostic report! I'll try and post up some pics when I get chance.
Great to hear... When I spoke with the guys at CARSOFT in EU they told me that they would not guarantee that the software worked completely with the Crossfire... So, I decided to take a different route and am ordering the Ease Diagnostics Chrysler software from TunerTools...
If you haven't done so already, take a look at my data from the track last weekend... I'm still trying to figure out the LTFT / STFT / TIMING retard...
