Old Jul 20, 2007 | 10:34 AM
xfire2005's Avatar
xfire2005
Default Re: Crankshaft Position Sensor
This should do it for you.
Service and Repair
REMOVAL
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner housing.
  3. Disconnect the crankshaft position sensor harness connector.
  4. Remove the retaining bolt and the crankshaft position sensor (1).
INSTALLATION
  1. Install the crankshaft position sensor (1) to the engine. Tighten to 8 N.m (71 in. lbs.)
  2. Connect the crankshaft position sensor harness connector.
  3. Install the air cleaner housing.
  4. Connect the negative battery cable.
