Old Jul 23, 2007 | 11:20 AM
xfire2005's Avatar
xfire2005
Default Re: instrument cluster removal ?
This should help, and yes, it states to remove steering wheel.
Instrument Cluster Cover
REMOVAL
  1. Remove the steering wheel.
  2. Remove the lower instrument panel.
  3. Remove the sentry key antenna ring from the key cylinder.
  4. Remove the screws attaching the instrument cluster cover to the lower instrument panel.
  5. Disconnect the instrument cluster cover (1) from the top with a plastic wedge.
  6. Tip the instrument cluster cover toward the rear at the top. Lift it over the jacket tube covering and simultaneously guide the adjustment ***** through the cover.
INSTALLATION
  1. Tip the instrument cluster cover toward the rear at the top, then lift it over the jacket tube covering and simultaneously guide the adjustment ***** through the cover.
  2. Connect the instrument cluster cover (1) to the instrument panel top section.
  3. Install the screws attaching the instrument cluster cover to the lower instrument panel.
  4. Install the sentry key antenna ring to the key cylinder.
  5. Install the lower instrument panel.
  6. Install the steering wheel.
