Old Jul 25, 2007 | 09:07 AM
jmswllms's Avatar
jmswllms
Default Re: Toyota v-6, pathetic
Here's the specs for the V6 '07 Camry.
LE V6 SE V6 XLE V6 Engine 3.5-liter DOHC 24-valve
Dual VVT-i V6
268 hp @ 6,200 rpm
248 lb.-ft. @ 4,700 rpm Standard Ignition Electronic, with Toyota Direct Ignition (TDI) Transmission 6-speed electronically controlled automatic overdrive with intelligence (ECT-i)Standard Drivetrain Front engine, front-wheel drive Body construction Unitized body with front and rear vibration-dampening sub-frames Suspension MacPherson strut front suspension with gas-filled shock absorbers and stabilizer bar; dual-link independent MacPherson strut rear suspension with gas-filled shock absorbers and stabilizer bar (SE adds sport-tuned shock absorbers and springs, strut tower and trunk-mounted braces) Steering Variable-assist power rack-and-pinion Turning circle diameter, curb to curb (ft.) 36.136.136.1 Brakes Power-assisted ventilated front/solid rear disc Standard 4-channel 3-sensor Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist [4] Standard Vehicle Stability Control (VSC) [5] with Traction Control (TRAC) Available
