Re: Help Brake Pads
If the rim hasn't been off in a while, there is probably some corrosion between the aluminum rim and the steel disk hat. If you bump the edge of the rim with your hand on one side then the opposite side, it should break free.
Hope this helps.
Bryan
#22 D/Stock
