Thread: Help Brake Pads
Old Jul 29, 2007 | 04:57 AM
HDDP's Avatar
HDDP
Default Re: Help Brake Pads
Originally Posted by mrobinsoTto all (including those who doubted me)... I had the car jacked up first of all. After hammering the rubber tire from all angles the tire came loose. Grime and corrosion was strong enough to hold the tire in place. Installed my rotex gold pads front and back. I feel like the back pair is making some noise. I figure this is just wear in noise... please let me know if I should be worried. [B
The pads I removed from the rear had metal covers that covered parts of the brake pad surface. Rotex gold pads don't have those correct?[/B]
Please don't take offense, but it sounds like you probably should not be doing your own brake job... remember these are the things that prevent you from hitting the wall...
If you are unsure if the pads are installed correctly, or if you bled the hydraulic lines properly, perhaps you should get some help ...
We really hate to see a good Crossfire destroyed like this: http://video.google.com/videoplay?do...arch&plindex=0
