Thread: Help Brake Pads
Old Jul 29, 2007 | 01:15 PM
HDDP's Avatar
HDDP
Default Re: Help Brake Pads
Originally Posted by mrobinso
I understand your doubt you guys. But I did everything just as andrew's DIY, as well as the Porterfield replacement DIY on the forum, and slk32.com's DIY. I am sure everything is installed properly. I didn't resurface because andrew said it wasn't needed and also because my brake pads looked like they had a lot of life left on them (half inch left). Now if someone would be kind enough to answer my question. Do the Rotex Gold brake pads come with a tiny metal clip covering part of the brake pad surface for the rears or not? THANK YOU.
Deep breath... We're just busting your chops... I don't know ! I use Porterfield pads... I think you're talking about a metal clip that acts as a wear sensor so when the pads start to wear down, the clip rubs on the disc and squeals to let you know your need new pads... If that's what you're talking about then is doesn't matter since I'm sure you replaced your wear sensors when you replaced your pads...
