Originally Posted by qshyboy
Thanks for your reply, Fritzauf. Although, doesn't it rub against the A frame bolt on the top? Also, is the spacer for your rear necessary, or is it used only to make the rear look good?
If I may? You won't want a spacer in the front. IMO. It would be outside of the well, and yes it will rub without a spacer. 18x8 is what fits. Now if you do go with a spacer in front, say 5mm, then you will need a 25mm in the rear. I have 18x8 on front, no spacer, and 19x9.5 on back with 20mm spacer. I believe most have this setup with aftermarket wheels. If they don't you can tell! Big-time! My $.0234. Good luck!
