The kickdown simulator is not used as a "kickdown switch". Wide Open Throttle (WOT) recognition takes place over the signal from the accelerator pedal position sensors pressure point, which is located in the pedal assembly. WOT position is simulated before achieving the full load position.
This is from the CF service manual.
