Old Aug 7, 2007 | 12:02 AM
NeverEnough's Avatar
NeverEnough
Default Re: Took Her to the Track Last Night...Ran better than expected.
Originally Posted by Buck70
With the right conditions Fflores will be one of the first in the 12's stock.
His car has been freakish fast on the MPH with most of us only running 105-107 in the qtr. My best so far is a 13.005 but my MPH have never been over 105, in the 2 track outings I've done. Our coupe weighed exactly 3,000 lbs empty on the scales at Memphis Motorsports Park.
DB
How did you do that? What was your 60 Foot? It must have been in 1.6-1.7 range to get a 13.005 at only 105. I could see it on drag radials. I've actually thought about buying a set for xfire, but I'm not sure the rear diff will take the abuse...
In ideal conditions, I think I can massage a 1.8 60 ft out of the stock PS2s. They seem sticky enough. I'm going Virginia Motorsports Park(VMP) when it cools off. With EVERY car I've had, VMP runs about .2 faster than Richmond Dragway. If that trend holds true, and I get the launch down a little better, I think a 12.99 will happen... I've seen several 13.0xxX runs. I have to believe that a few thousands of a second can be found SOMEWHERE.
