Old Aug 7, 2007 | 09:26 AM
xfire2005's Avatar
xfire2005
Default Re: Kind of off Subject But Not Really
Originally Posted by HDDP
I know we have a diversified group of people here... I need to find a small "WET VACUUM" with a 1/4" hose that has about a quart holding tank that runs off either AC or DC doesn't matter... Preferably "off the shelf", I don't have time to build a vacuum pump...
anyone know of such a beast ?... I've been searching the internet without results...
Those members who took a look at my post about the intake manifold and saw the photos of the varnish "crap" that has decided to take-up residence in my engine will understand my immediate need...
Since I have the top-engine removed which exposes the intake valves I'm going to use spray MAF cleaner to remove the varnish, but do not want the residue to seep into the cylinders... So my thought is to use a small wet vac adjacent to the spray tube so as the "CRAP" breaks loose it is immediately sucked back up... Kinda like that little suction tube your dentist uses...
PS: MAF cleaner really takes that stuff off fast...
You might want to look at this:
http://www.shopvac.com/vacs/list.asp...dex&Browse=1hp
Larger than what you asked, but with the crevice tool attached, should do what you want.
