Old Aug 8, 2007 | 09:46 PM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: What's The Biggest 18" Tire On The Front
Keep in mind that if you go to 235 or 245 width tires without lowering the profile you will probably begin rubbing/cutting into your tire with the upper ball joint bolt and nut.
If you lower your profile to 35, you should gain the extra space to clear the upper ball joint bolt and nut.
Compare for yourself... (Handy wheel / tire size comparer found here).
