Originally Posted by knell1906
Greetings,
I'm new here. I decided to register after browsing the internet trying to figure this out...
I have an 04' coupe. Sometimes I hear a slight rattle on the rear drivers side. What could this be?
I did a search but I guess I wasn't using the right key words.
- Keith
If it sounds like it's in the rear, it could be the hatch. Mine was really bad. It is easy to fix though. Open the rear hatch, on both sides, you'll see a black, plastic, bumper with an adjustment screw that, when closed, rests on the body inside the hatch channel (pretty lame arrangement). Just loosen the screws and slide the bumpers down as far as they will go and still allow the hatch to close. Once you get that set, tighten the screws down extremely tight. you may even want to use some thread locker.
Hope that helps.
