Old Aug 9, 2007 | 08:39 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: What's The Biggest 18" Tire On The Front
Originally Posted by MMZ_TimeLord
Keep in mind that if you go to 235 or 245 width tires without lowering the profile you will probably begin rubbing/cutting into your tire with the upper ball joint bolt and nut.
If you lower your profile to 35, you should gain the extra space to clear the upper ball joint bolt and nut.
Compare for yourself... (Handy wheel / tire size comparer found here).
Yeah, that bolt was my main worry. I was using this calculator yesterday and scratching my head, the wheel are suppose to be delivered on the 10th. I still have to order lug bolts and possibly some spacers with hub centric rings, I figured I would wait till I get the wheels to see what kind of issues I'm going to run into. Like how long of a lug bolt I'm going to need, ball seat or conical, hub centric rings & or spacers.
