Originally Posted by r.robertson
Crossfire owners, My car detailer said he was going to start selling a product called Ultra Seal for the tire.
www.ultrasealuk.biz
A TYRE LIFE EXTENDER/CONDITIONER, & PERMANENT PRE PUNCTURE PREVENTATIVE
Ultraseal is a special blend of 24 chemicals in a viscous liquid state which coats and clings to the inner wall of the tyre. Utraseal is a "permanent" puncture preventative and tyre life extender/conditioner, and we believe the only product on the market today that is guaranteed to work very long term in a high-speed tyre. Previously available products (and most current ones) have simply "fallen apart" at speeds of 40 mph and over, because they were manufactured for the construction industries slow vehicles, but eventually made their way into the high-speed markets creating problems. Ultraseal is not a get you home product, it is applied before the puncture occurs, and permanently seals puncture after puncture in the tyre as they occur. Once installed, Ultraseal not only seals punctures, it conditions the inner casing, preventing porosity leaks caused by tiny holes and cracks. In other words after installing Ultraseal the tyres maintain correct air pressure and the need to regularly top up with air is virtually eliminated, and with correctly inflated tyres you get better fuel economy, your tyres also run cooler eliminating that killer problem of devastating heat build-up. Tyres treated with Ultraseal last considerably longer, and unlike temporary sticky oil based sealants, Ultraseal is water based for easy clean out if ever you need to do this. Ultraseal is installed in minutes through the tyre valve with very little air loss and without removing any wheels
There is a brief description any comments
:wink:
i have tried this product and it
will put your tires out of balance...junk imo.
not recommend.
