Old Aug 10, 2007 | 07:43 AM
woody's Avatar
woody
Default Re: Just Did Throttle Reset - WOW!
Originally Posted by Copernicus
So, I take it that this "learning process" is constant. No matter how many times you reset, it will eventually reset again, on its own.
Yes. Its a bit sketchy on the details of the number of response curves but the manual states:
The PCM recognizes how the accelerator pedal is being pressed and switches between a few characteristic curves.
Eighty percent of the engine’s power is achieved for a pedal travel of about 50% for an aggressive driver and about 40% for a conservative driver. There is no further difference felt above a pedal travel of about 90%.
The characteristic curve for a conservative driver is active after a long drive. Then the accelerator pedal must be pressed down unusually hard to obtain a higher acceleration level.
