Old Aug 11, 2007 | 08:25 AM
Louie K's Avatar
Louie K
Default Re: Are the engine management module and relay module the same?
Originally Posted by HDDP
The way you access the DTC's is through the OBD port and a scantool... You won't know what is causing the CEL until you read the codes through the scantool... So, until that happens I can't help you...
I appreciate your persistence trying to help me. If the dealer ever gives me the code I'll pass it on to you guys. Thanks again.
