Old Aug 11, 2007 | 06:50 PM
NeverEnough's Avatar
NeverEnough
Default Re: Headlight aiming
Originally Posted by juan vega
careful when you turn these white *****... cause mine was already broken and the lamp is $700. oh yea my light is still pointing down.
They are only about $100 on Ebay. And, it's probably not broken. If you screw the shaft in, it will eventually "POP" back into it's seat. Then you're all good. Once I pulled out a couple things in the way, it only took about 30 seconds to get it back in. You notice the headlight assemble starts to move a little when you screw the shaft back in. it will eventually snack into the headlight adjustment mechanism. Then you just need to adjust it as normal. If not, then look on ebay, I've seen lots of complete headlight assemblies on there for less than $100.
