Old Aug 22, 2007 | 08:34 PM
Mike-in-Orange's Avatar
Mike-in-Orange
Default Downloadable NAV CDs
UPDATE: As of 01.25.13 the download links have been updated
There seems to be a lot of comments about missing NAV CDs in the "Inventory Reduction" cars and I'm sure somewhere along the line folks will misplace or damage the ones they do have. My car only had the West Region disk in it but, with the gracious assistance of crossfirefun (AKA Phil) I now have the East Region as well.
These disks are for the Infinity Modulus System only, they will not work in other NAV systems. So to share the wealth, so to speak, I have both sets of files sitting on my FTP server and links to both right here:
East Region Nav CD (622MB)
West Region Nav CD (478MB)
Be warned, the files are quite large and are in .ISO format. The following instructions should result in working disks - I tested both methods and produced working disks both ways.
Make sure to use the correct media for this project: CD-R media is the ONLY media that will work. CD-RW discs or DVD media of any type will not work in your Crossfire's NAV unit.
Windows Computers:
Using Roxio Easy CD Creator:
1. Launch Roxio Easy CD Creator
2. Select "File" > "Record Disk From Image"
3. Browse for the file you downloaded (either XFIRE_USA_0015.1.iso or XFIRE_USA_0015.2.iso) and select it
4. In the resulting pop up window select "Details", then select "Disc-At-Once"
5. Select "OK"
6. Once burning is complete the disk should be useable in your NAV system
Using Nero Burning ROM:
1. Launch Nero and close out the "New Compilation" popup window
2. Select "File" > "Open"
3. From the "Types of Files" selector, choose "Image Files (*.nrg, *.iso, *.cue)" and then browse to the file you downloaded (either XFIRE_USA_0015.1.iso or XFIRE_USA_0015.2.iso) and select it. NOTE: you will not be able to browse to the file until you have chosen the correct file type from the dropdown menu
4. From the "Burn" tab, select "Finalize CD (No further writing possible)" and next to "Write method" select "Disc-at-once"
5. Select "Burn"
Apple Computers:
(Many thanks to djreact33 for the following instructions on burning these files to disc on a Mac)
Originally Posted by djreact33
Very Very easy to do... I did it last night.. But then again, these directions are for MAC users. Dont know if they make ROXIO TOAST for shitty PC's..
1. Download the NAvigation files. I know there is a thread around somewhere b/c i used it yesterday.
2. Get yourself Roxio TOAST. I use toast 7, doesnt matter what version you use.
3. Open Toast. Make sure your creating a Data CD, not a Audio CD. Then select the "IS0 9660" option on the upper left hand side.
4. Click and Drag the .iso file to where is says, "Drop .iso file here"...duh
5. Burn that *****!!
I did it last night and had no problems what so ever. Hope this helps.
