Originally Posted by andrew
i'm almost certain the base is without the tpms... this is why the base crossfire has rubber valve stems and not the aluminum (sensor attached).
If the base model doesn't have them, do you think they have an ECU override that makes the car think that they are always functioning, or do you think they have the complete system removed from the car?
I'd rather not have these as they seem to do more harm than good. Most of the car enthusiasts who own this car are bright enough to peek at their tires every other trip and make sure the PSI is acceptable. Although...I will say the sidewalls don't show much difference between 25 psi and 50 psi.
I wonder what it takes to 'remove' this function from the limiteds.
SQ
