Originally Posted by DFWSBR
It is a simple adjustment the dealership can provide. If they need specific information on it, tell them to look up:
TSB Number 23-023-03 Dated October 17, 2003
I have a copy of it in my hand as we speak.
It is not "normal" for the vehicle to have wind noise, however some were just not adjusted properly from the factory. It covers all builds as it is not a defect but an adjustment. I checked to see if my window was going up too high, that is not the case on my car.
A few questions about the Wind Noise TSB, please.
1. Where can "we" get copies of this TSB or any others for that matter?
2. Would it be unreasonable to ask the dealer and have him show me the TSB before letting them preform the work?
3. Is the window TSB a two part fix:
a. Adjust the seal first?
b. Then take the door apart to adjust the window track itself if the seal adjustment doesn't work?
It would be nice to be informed of the work they are supposed to do. Being knowlegeable on the subject may help keep from having to take the car in several times for the same problem.
You guessed it... I had my car in for service and still have the wind noise. There is a small gap about 4-5 inches long starting from the front corner of the window where I can easily push the key in. The passenger's window is sealed tight and has no such gap.
My "freindly" service writer mumbled something about adjusting the seal. The repair invoice states the dealer's fix was,
"Adjust the mirror flag weather strip as per TSB23-23-03... Repair verified by SKM".
Thanks for any input.
