Old Aug 27, 2007 | 12:02 AM
mbepic's Avatar
mbepic
Default Re: Stock Exhaust Specs
Originally Posted by sharptech
i would think that cutting the exhaust right before they collect into one and finish out with dual all the way out would help power...question is does the exhaust go from two 2.25" into one 2.25" then into the muffler? that makes no since.
The exhaust is FULL dual exhaust...no stock muffler or other muffler whatsoever.
Originally, I used free flow converters but that was a big mistake...converters are meant to function much closer near the engine where heat is very high. In my original set-up, the converters degraded and eventually plugged.
I replaced those converters with stainless steel resonators and new stainless oval tips that are slightly angle cut. The look is much better...the over-all quality is much better and the sound is as good. The factory CATS are untouched and I have kept my original factory pipe and muffler/rectangle tips in case I sell the car and the buyer wants it back to original specs.
I am now going to investigate an 'X' Cross-over pipe, to scavenge the exhaust better and I believe retain some of the original low-end torque that I may have lost with this conversion. I believe I have definitely increased high-end performance and improved fuel mileage over factory specs.
If anyone wants the part numbers and pics of my latest exhaust set-up, send me an email at: mbepic@gmail.com
I have just come back from the Mosport, Ontario ALMS races and my Xfire sound would be right at home there, however, I was in a much quieter '88 Corvette.
