Thread: Wrong oil
Old Aug 30, 2007 | 01:23 PM
cudaman's Avatar
cudaman
Default Re: Wrong oil
Originally Posted by DanielNTX
If it's fully synthetic it should be okay. I was talking to my petroleum engineering friend and said there isn't much difference between 5w30 weight and 0w40 weight oil, just a slight difference when in cold temperatures. The kinematics viscosity is slightly different at 100 degrees celsius for each oil, but I wouldn't worry about it.
Ya, you should be fine. The diffs are only for temp differences. If you drive the car with low coolant on a hot LV day at 115 degrees and keep it floored for hours, then you might have an issue. A trip to the grocery market and back won't make that big a deal. Change it to 0-40W next time around, unless you want to be overly **** about it.
