Old Sep 1, 2007 | 05:21 AM
HDDP's Avatar
HDDP
Default Re: Redline with the ESP fuses pulled!
Originally Posted by stallion8797
OK I may sound stupid but, is there a fuse for it? A plug? A "disable yaw sensor" button?
It's a wiring harness connector that attaches to the sensor... Just press the side tabs and pull... If you don't know where the YAW sensor is, it's located under the center console just aft of the shift mechanism.
But as Woody said, you will throw a light on the dash... But it will go away after a couple of driving hours after you re-attach the sensor wires...
