Thread: Headlight Help!
Old Sep 5, 2007 | 08:46 AM
danimal's Avatar
danimal
Default Re: Headlight Help!
Originally Posted by Cruiser
If that's what your thinking, there not seated correctly,what would I tell them? Is there a trick to installing them a correct way that I can tell them? Since they must not know anything...
Thanks!
I can only tell you that after replacing mine, it took 2 or 3 times to finally figure out when it was seated correctly. After that, the rest of them were much easier to install. If it is only illuminating a short distance in front of the car then the bulb isn't installed correctly. Good luck.
