Old Sep 8, 2007 | 07:37 AM
HDDP's Avatar
HDDP
Default Re: Ecu Reflash With Custom Turbo Possible?
Originally Posted by basslover911
^^^ Yes sorry for that. ^^^
Anyway, as far as timing that will not be a problem. First off, the ECU can pull or put in timing (but I KNOW, it can only do it to a certain degree). Now, a way to help with the timing (and add hp) is to add water injection.
Tito @ TR
With all due respect, you are delusional if you think just adding a piggyback FMU and a water injection system will allow the ECU to adjust the timing on an aftermarket supercharger install and properly operate the engine...
