Thread: Bring it on!
Old Sep 9, 2007 | 08:44 PM
HDDP's Avatar
HDDP
Default Re: Bring it on!
Originally Posted by Punkin
OK, I know having lived as long as I have I should know this but I don't. I want to replace my standard SRT rotors with performance ones and paint the calipers. This means removing the calipers completely as Andrew suggested. I've replaced many brakes in my short life but have NEVER had to break open the brake lines before. May I ask how is the best way to bleed the air from the lines so as to not run into the Yugo at the next stop light?
Well, since you're going through the trouble of pulling the calipers and rotors, you might as well spend an extra George Washington and replace your lines with braided stainless steel lines from Goodridge...
That being said, just remove the lines and place the detached end pointing to the sky while you work on the parts, this will help prevent air bubbles from working their way up the line... Then use the normal bleed procedure for all hydraulic brake systems...
