Originally Posted by NeverEnough
20 WHP!!!??? With the Pulley setup and ECU tune??? That makes no sense. If that is true then it's TOTALLY NOT WORTH THE EXPENSE! How much does the Renntech kit add?
Is there a website for the ASP pulley? I found their website, but searched it high and low and could not find anything for an SRT-6, a C32 or an SLK32... Am I missing something ???
Don't take 20 rwhp for granted, you'll notice it quite a bit.
You have to contact them directly and ask for it, you are correct it does not show up on the site. Here's from the e-mail response I received when I inquired about the pulleys for the SLK32 (has part #). Claims 20 hp to the wheels without reprogram, but I got the reprogram and only got 20. I cannot attest to any difference with or without because I did them at the same time.
Also, his name was Lee, and his e-mail address is
asp@aspracing.com
> You need pn 331380 , crank, wp and idler pulleys. This kit:
> Retains the factory belt for $970, good in stock. 20 hp to the wheels.
> Without an ECU reprogram.
