Originally Posted by sharptech
Fuse box driver side against firewall. Under hood. Hey how did you pull the yaw sensor what do you mean?
I Read in this forum that disconnecting the YAW sensor located under the center console behind the shifter would be the only way to disable the TC fully. So i popped off the entire bezel, cover piece around the shifter and took out the two screws and got two flat head screwdrivers to undo the pins on the center console and pulled up, revealing the sensor as described. i unplugged it, the ESP BAS light appeared on the dash, but the car still can't burnout and still can't bone out into second gear.
Justin
