Originally Posted by James Sonne
Yeah, well my tires can hold 54psi. That's the maximum level before they explode. I'm just saying, the tire pressure sensor probably senses pressure and if it's out of spec of a hardcoded level then it will go off. Every tire has a different psi level, so the sensor probably won't work for every kind of tire or rim regardless of whether or not it physically fits.
Where do you come up with this stuff..... There's not a tire on the market for this car that will not play with the TPM. James.... go play with your acura and quit making dumb statements... Please!!! I let most go but this one is just to dumb to ignore.:?
If your tire has "max pressure 54 psi" on it that means that 54 psi is the highest pressure you can safely use. It's not going to explode if you put 55 psi in it.
