Old Sep 23, 2007 | 07:30 PM
former NXMX5's Avatar
former NXMX5
Default Re: Blaupunkt SD-Card Stereo
Originally Posted by bobs
* The harness does not supply connections for the front speakers, so you will need to run new speaker wires to your front speakers.
* The harness does not supply connections for the rear speakers, so you will need to run new speaker wires to your rear speakers.
* When used in this vehicle, the functions of the yellow and red wires in the Crutchfield harness are reversed. The yellow wire supplies ignition power, and the Red wire supplies constant power.
* You will need to bypass your factory amp by running new speaker wires from the radio to the amp location and splicing the new speaker wires to the factory speaker wires at the output side of the amp.
* Questions? Call 1-888-955-6000 to speak with an expert.
nothing to worry about. use the pre-out to feed the front speaker wires... problem solved.
