Old Sep 25, 2007 | 06:36 AM
Cincinnati Slim's Avatar
Cincinnati Slim
Default Re: My Crossfire has broke down and I need help :(
Sounds like the engine is starved for gas.
When the key is turned to the ON/RUN position can you hear the fuel pump running ? If not the fuse may be blown or the pump failed.
Do you hear the pump run? Then the Simplest, most probable cause is a blockage in the fuel filter. It might be partly clogged. Hope for this because it's a cheap easy fix !
Slim
