Re: Intercooler...
Replace the heat exchanger with the largest size you can fit in front of the AC heat sync... Separate your charge air cooling system from the OEM plastic overflow tank that is shared with the engine and install a cooling plate type tank... Insulate the cooling pipes going into your charge air cooler... Install the frenolic gaskets available form the euro tuner companies...
