Re: Will this fit?
What offset are you looking at? If you stay around 32-35mm offset you would be getting into to range that could be fine tuned with spacers. At only five inch wide in the front that is a non issue. Are you setting this car up for drag racing? They spacers will be for the rears depending on offset and maybe the front if you cannot get the center caps on.
