Thread: Question!
Old Oct 3, 2007 | 04:15 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Question!
Originally Posted by ZERACER
I am buying the Stern ST1 wheels from Silver Fox. I assume the TPS tire pressure senders are independent RF units. Can they be installed in custom wheels and still do their job? If not, how would you disable them so the warning light is not constantly on? I would like to keep this feature, if possible.
Thanks.
I put Stern wheels on my car and the tire shop recommended that I not use my OEM sensor's without an adaptor. So I went with out them and removed the bulb from the dash, (PITA). I liked the Idea of having my OEM wheels, tire's & sensors all in tact anyway. I almost bought a extra set of sensors & adaptors, but the sensors were going to run about $90 each. You will also need 10mm hub centrical spacers for the front to get the center caps on. Also the spacer will not fit over the spindle, you'll have to turn 1.1mm out of the center, (inside) for them to fit.
